It is currently Fri Jul 25, 2025 9:45 pm
PostPosted: Fri Mar 14, 2008 10:02 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Anyone heard of black fretwire called Nylatron? I've seen it on Michael Peters website, he's using it on classical guitars. It wold work well with a project that I'm planning. Any idea of where to get it? a quick google search this morning didn't turn up anything, other than a like to Micheal's website...
http://redrivercanoe.ca/
PostPosted: Fri Mar 14, 2008 10:07 am
Wow????? Nylatron is a plastic like polymer Harder and more ridged than UHMW. We use it as bushing material for non lubricated shaft situations. I never knew that frets were ever made from it. i suspect he is machining his own from round bar stock Nylatron
PostPosted: Fri Mar 14, 2008 1:23 pm
Last Name: Garrish
The stuff is pretty hard for a polymer, it's Nylon with a hard filler. I think it would stand up pretty well on a classical, as it's being used there. Questionable on a steel string, though maybe I'll run some tests just to see.
Bob Garrish
PostPosted: Fri Mar 14, 2008 1:29 pm
I think there is wide agreement that plastic saddles, even when made from fairly hard plastics, dampen vibration and hurt the sound of a guitar. Why would this not also be the case if one put plastic in contact with the string at the other end?
PostPosted: Fri Mar 14, 2008 5:53 pm
I agree with Howard, and would add the question - what improvements or desirable aspects would guide a person to choose a synthetic like this over traditional wire?
PostPosted: Fri Mar 14, 2008 6:29 pm
First name: Erik
Last Name: Hauri
State: Maryland
The answer is obvious....so that you get even tone up & down the neck when using a plastic saddle! duh
The member formerly known as erikbojerik....
PostPosted: Fri Mar 14, 2008 6:32 pm
I assume that these would be glued in. If so, do some research on what the appropriate adhesive is, as nylon is difficult to bond to.
PostPosted: Fri Mar 14, 2008 8:48 pm
Last Name: Garrish
Blackness. Check out how much the black plastic they make MacBooks out of costs!
Bob Garrish
PostPosted: Fri Mar 14, 2008 10:08 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I've just heard about this stuff today. I have no idea if its any good.
Blackness is indeed what was appealing to me.
I had in mind a deep chocolate cedar soundboard on similarly dark body wood, ebony fingerboard and headstock, Classical guitar. Maybe black tuning machines, too. the black fretwire sounded like just the thing to set it off, unless there is some good reason not to.
PostPosted: Sat Mar 15, 2008 11:44 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
You're building this for Darth Vader? ;) ;)
Hank Mauel
PostPosted: Sat Mar 15, 2008 2:28 pm
Ahhh, aesthetics at any cost. This is to be a showpiece locked in a glass case...
"Form follows function", does it not?
PostPosted: Sat Mar 15, 2008 7:40 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
No. Not aesthetics at any cost. Not life stuck in a glass case.
A certain goal in mind functionally, and aesthetically. Now, collecting ideas about how to put it together. Making a good guitar is the first priority. Determining the look is an extension of that.
PostPosted: Sun Mar 16, 2008 12:21 am
I've never used it myself but I have seen others use 1/8" black Delrin rod for classical frets. They are set in a square channel just a bit deeper than half of the diameter and epoxied in place. With the right depth, the epoxy locks the frets in place. It seemed to work quite well.
